  • Replies 55
found some. the spout turned to feed into the box and i had barn doors on the back for tipping, the chipper hopper had a lock so i used it as a tool store to and from jobs, it was a bit high to feed but it was never designed for dragging massive heads to the unit, it was constructed from 25mm x 25mm with an inner skin of 2 mm either alloy or galvanised steel (i cant remember) but it was mounted on a seperate tipping chassis with a 5 ton underbody ram. i think i had it about 11 year ago.:biggrin:
Good effort, but like you say, a tad high to feed easily. How did you get on with the overhang behind the rear axle, did she get a bit light on the handlebars?
