Is there any reason why I can't use a Whoopie sling as a cambium saver
  • Replies 72
Your using the device for something its not intended to.
Cambium saver is made for this job in hand.
Its like using a pole pruner for sending up a truck on the ground.There's always something made to do the job in hand
Sometimes you've got to improvise and make do.
I would say us tree people are some of the most problem solving people out there :thumbup1:
It's good practice to not mix PPE (climbing gear) & Rigging gear. Mark it as PPE or Rigging and use as such.
However, in an emergency you have to use what is available.
Edited by Greg
more text
I see what you mean Tom But if something is available for the purposes and its not expensive.
Why not use it?
Good idea. Cheaper than a Ropeguide for example, And pretty much the same thing. Get a little tenex loopie sling, Mallon and a Pinto pulley and I reckon you'd have a sweet little set up mate.
Not designed for purpose but serves a purpose all the same.
Why not use it?
But a normal cambium saver isn't availiable for the purpose! A rope guide is, but you're looking at mega bucks. If I'm right the OP needs to attach a line on a pollarded stem, Not over a normal branch like a normal cambium saver.
Thats how i read it also...
Feel like a tit missed that bit completely.:blushing:
(Note to self Read everything)
Correct!
Thanks for everyones advice and points
