Brushcutter
billy110
I have an acre of brambles to get rid of and I want to buy a brushcutter. This isn't my line of business, I'm a sparky, so I don't want to spend a fortune but at the same time I want something fairly heavy duty.
I have been looking at the stihl fs90 as it has the solid shaft. What is the husqvarna equivalent. The huskies run on petrol only, is that an advantage over running on 2 stroke?
Any thoughts would be greatly appreciated.
Billy
Lime Electrical
Billy
Lime Electrical
the fs90 wouldnt b man enough... try the fs130 or if you have the money an fs400 is the sharpest tool in the box
I have a Kawaski KBH43 (43cc), I much prefer it to similar sized Stihl or Husqvarna models I have used. I'm quite tall, and find that as this one has a longer shaft it's much easier to use, don't know if that would be a factor for you or not.
If you want something fairly heavy duty, I'd go for at least 40cc whatever make you choose. And get one of these blades for it, they're perfect for knocking down brambles and mashing it all up!
Oregon 12" 300mm x 4mm Brushcutter Blade 2 Teeth 25.4mm on eBay (end time 22-Mar-11 15:09:17 GMT)
Both of the Stihl models are much more expensive than I wanted to spend, the £400 mark was a bit steep for me but don't mind spending it as it's good gear. The Kawasaki is coming in at £500 so is a bit over budget
but the fs90 is no good for anything more than grass, it even struggles with long grass, try get hold of a used fs400 or an fs450
