192T where from?
Jenny Tool
you will often find them with a 14inch bar, that is the standard bar they are sold with here in france.
as i started out on a very small budget i have had a 192t from the start, i have been using it as my main climbing saw for 3 years now and never had a problem with it, they are not that fragile (nothing broken yet). jthey are maybe a little under powered, but i have fitted a pico bar and chain (still 14inch) to mine and it runs really well on that.
Unless all you're doing is light pruning you'll have to buy a 200t as well.
I have the ground variety i.e. 192 and it's a good little saw for carving but struggles with anything over 8" or so
i have two,ones good for parts since some so and so dropped it from about 10 metres onto rock.
over here a 192t will cost about $630 and a 200t about $1600
there a good little saw with a 12'' bar and 050 chain and bar on it
the chain and bar it comes with is rubbish
Also being mostly plastic inside the bar area palms eating out the casing is not an issue
never used a 200t. have used a 020
