Timber / Pulp Tongs Holster ???
TimberCutterDartmoor
I currently use the pictured Husq tong holster; point is it seriously does my head in becuase of that stupid rivet slap bang in the middle of the pouch area - if it's there to stop the tongs falling out then it flippin well works but that is the problem - it's so tight I am forever fighting to the get the tongs out.
So, can anyone reccommend one? Had a Stihl one in the past which was better and no rivet but thought I'd ask.
Thanks.
A petzl carry tool on your belt (like you would have on a harness) and a small keyring ring, or tiny krab, or a small piece of cord through the hole in the handle of the tongs.
Cheap but effective. I just completely made that up but it may be a good idea???
Dont worry, I had a Husky one and it fell apart in no time, I have now had the Stihl ones for quite a while, and there are no probs with either using them for tongs or wedges. The rivets dont seem to get in the way either :thumbup1:
I was interested in the two rings on your high lift wedge. Is there a reason for this?
Ah yes, 2 rings dont move on the head of wedge, which helps prevent mushrooming when driving it in. The rings seem to lock off against one another. Another tip I leaned when wedging is to use a hammer weighted with shot, which doesnt bounce on the wedge so takes less effort to drive it. :thumbup: Cheers Mike Hill for that
Two rings is a must for Hi-Lifts been doing it for years. Makes them last a lot longer. Another trick with the hilifts is not to use a very heavy hammer or the wood just tends to snap. I hear they use to come with two but now you must buy the extra one:sneaky2:
I guess i must be lucky as i've never had any problems with my Husky holders. The STIHL ones do look a little better though. Whats the extra hook on its own for Andy? An Axe?
