The "UJ" on the Top Feed Roller Shaft in my Jensen 528T is becoming Slogged out.Does anyone know where I can source a complete replacement?
I require the entire assembly as the Roll pin has sheared a number of times and the UJ ridden up the output Spline and Slogged the UJ out.
I would like to Source the parts outside of Dealerhsip Channels,as I paid £600 for "Special Bearings made soley for Jensens" to find them available for 1/3rd of that elsewhere.
I get anything like this from a local bearing supplier but if you are in Norway? that might not be a lot of use to you. If you are stuck I can take mine to them and get them to source the UJ
Andy
Wow £600 for stock bearings is a Huuuuuuuge kicking and don't you just hate it when they piss down your back and tell you it's raining?
My chap supplied the bearings (timkin) for the top roller for less than a tenner each
I have bought uj's off here before, my old man has an account with them if you have trouble ordering. you may have to trawl the site checking dimensions to find something that will fit.
Search Results
give us a ring if you need any help:001_smile:
Thanks Tom!
Thanks Mr Treequip,the Bearings I got Raped over were the Main Bearings.I will measure the UJ and make some phone calls,it dosn't have any manufacturers name on it.
