Hi Folks
Is anyone aware of any incorrect way that you could use a lanyard to prevent pendulum impact. Always thought that as a supplementary aid to prevent injury that you could use it either through the main bridge or side rings; using either the provided carabina or snap lock, am I being thick???:confused1:
regards
Dave
i suppose the only wrong way you could use it would be clipping both into one side ring, or for using it to suspend your whole weight on the side Ds.but if you have a main line attached then it just becomes a work positioning strop
I clip both ends on one side and suspend my weight off the d's when advancing my main line quite often! Should I not? Is it dangerous, I've always felt safe and always done it
Thanks Rob thats my understanding too, just having a bit of a debate earlier with some of my students who had a different take on the idea .. like to keep proactive though.
regards
Dave:thumbup1:
There are numerous rights and wrong, but you've got the basics right.
Il pop up sometime for a practical day, we need a catch up!
Hi John
Just give us a pm when you want to arrange..p.s hows teaching going:thumbup1:
Dave
Check out A guide to good climbing practice available from the following link..as Rob states supporting your weight off both side rings is considered bad practice when using an ajustable lanyard as the main attachment when advancing your main anchor point.
Dave:thumbup:
A Guide to Good Climbing Practice
When work positioning I do clip both into one side. I don't get crushed by my system then.
It works but it isn't seen as bad practice. I've hung off one side d briefly before now.
