Actually, I did have you down as a bit of a pikey..:sneaky2:
You've rumbled me Deano, It's my prefered alta ego for the weekends, don't you know .:sneaky2:
Would you look at the strength of
the man? I bet you can box a little
can't you sir? You look like a boxer.
KHCAAMWUXBCAMONXDPCAAZNT2QCA84W50JCA2NBWFPCAGOPOAWCA696GIMCAMOC56UCA4036ZXCA49Z9SOCA66URJUCAL97L.jpg.0a670a1a6e0cdbca710dc6be14d3968f.jpg
A close relative has similar soil - Sussex Weald clay a mile from Leonardslee Gardens south of Horsham - and has done well with working pea shingle into the soil. Ok, so he does it before planting (!) but I should think that in your case a fork could be worked in the root area followed by said grit worked into the holes and a good layer left on top for the worms to take down.
That assumes that drainage is the problem of course. How low is the pH? Low pHs often make trace elements unavailable, though present, as I'm sure you know.
