I have seen the dyneema rope break in use on landrover winches at winch challenges like anything it does have its limitations the only good thing is when it breaks it drops to floor rather than flail about like a steel wire !!!
yale double esterlon 19mm, the blue one, youll probably struggle to get close to half its breaking strain if you tried!
Nice rope. I use the 14mm as a pull line but would rather the 19, i had a tight budget at the time.
Amsteel Blue.
Light, extremely low elasticity, safe to work with, and TOUGH!
Expensive, though :hmpf:
Edited by morten
