Best market for 100 ton of Poplar?
  • Replies 21
If you are felling large quantities of other hardwood, just make sure that the popular get mixed in well. Nobody will notice, and it will save you alot of problems. Dispite so called common knowledge, poplar is not that bad a fire wood.
True, 3 winters ago it was all that we had available for the log burner and it kept us lovely and warm, like all woods, season it well and you'll be fine!:thumbup:
Poplar does burn nicely when dry. I've always been told it has a massive calorific value, which is why it makes good biomass chip. Mix it in with other thinning would be very easy to shift in mixed hardwood parcels. Poplar still has a bit of a stigma about it as a good firewood so a 100tonne parcle roadside would be a pita to shift. But any seasoned wood will burn.
Have you thought about cutting it at 2.75mand selling to a mill for sleeper cuts?
You'd be looking somewhere in the region of £25-£30 a ton at roadside I would expect.
Dunno what sleeper cuts are, but I'm guessing they might be the things to shove under things in lieu of pallets. If so, and you have the ability to mill that quantity, try haulage companies.
Sleeper cuts are done at the mill.... you just supply the logs at 2.7m - they use them for making railway sleepers!
Quite right, we should be able to tempt them back to the uk with all of the pop we've got hanging around because of their "outsourcing"
Poplar burns very well when seasoned, a process which is enormously shortened if you run a saw along the bark after snedding, as it has quite a waterproof bark.
