Blimey, that brings back memories. I corn/silage/dung carted with those in '78/79. Oil? Not a clue - whatever was cheapest that month I guess and had been put in the 50-gall drum with handpump.
No use to you whatsoever though am I. Soz!
I use a universal tractor transmission oil. Dont know what it holds but 9 litres sounds light. On another forum I read our 2140 should be warm and running when you check the level otherwise the level will be too low ?
