Hakki Pilkie 1 x 42 problem
Guest BOB WAUGH
Hi everyone
This is my first post so bear with me if my spelling or typing is a bit off. I have owned and run a Hakki Pilkie 1 x 42 greenspeed now for 3 years and find that reliability to be a bit of an issue. Bearings in particular seem to be very soft . to date i have replaced 8 beraings , 1 gearbox , 1 hydraulic motor, 9 belts and one complete chain drive assembly.:thumbup1::thumbdown: Has any one else had problems like this :thumbdown:
Guest BOB WAUGH
Cheers wood picker putting through roughly 1200 ton per year. We only cut soft wood , hey it sells :biggrin:
Guest BOB WAUGH
kinda thought that can you suggest a more suitable machine for me have looked at quite a few but need some help
Guest BOB WAUGH
looked at a repossessed Bindenberger looked like it had not done much but by the time i made my mind up it was sold. I like the Hakki Pilkie cause M Large are only 80 so miles away and give a really good service . What about the fuel wood firewood factory ????? any views:confused1::confused1:
bob
i run a 1x37( Easy control) Hakki owned for just over a year and had about 1000 ton pushed thru it. (90% softwood) I have not managed to trash any bearings yet but i am a maniac with a grease gun! I give every nipple a pump at least once a week. However i do go thru lots of belts. to date 6 sets of 3 off the main gearbox and 3 chainsaw belts. I use standard tractor belts as replacement and i suspect that they are not quite tough enough. maybe a belt made of a harder compound if available, would be better. they do seem to stretch every 50 tons or so. I suspect that the less sharp the chain is the more stress / wear in the drive belts. The chain may still cut but not easily enough.
not yet seen any sign of wear on the infeed or out feed belts.
how are you loading yours? I presume you have a log deck. if this is set at too steep an angle it can batter the infeed conveyor especially if you putting big diameter lengths thru. consequent stress on deck bearings and infeed belt and rollers.
I have noticed a small oil weep on the gearbox / pump but this is very small and has not got any worse. this started when the pto shaft i was using failed (sent shock thru machine?)
specifically what belts have failed on yours?
