Not to sound horrid but if you can't figure out from the above descriptions how to cut with a 15" bar you want nothing with a more powerful saw.I don't want to read another accident thread dude.there no joke powerful saws,the 15" will get it do the cut roll and join the cuts again,then wedge it open with a wedge pop saw in and go for the little bit in middle.
I've had to do just as big with a 16" before when my main saw died
No worries ! I had worked out that I could nibble away by cutting out blocks but it was just painfully slow. I just wondered if there was a technique that the professionals used that I hadn't heard off.
And yes - absolutely right an extra 3" on a new saw isnt going to make much difference. But if it can cut out a [slightly larger] block in less than 10 min and not need a rest to cool down afterwards then it might be worth a go.
... also potentially a good justification for a new toy to tell the Mrs :wink:
However I'll give the splitting approach hullsmillfarm suggested a go first (and then make a decision once I've buried 4 wedges in the trunk)
  • Replies 35
not sure id like to swing that axe, hell of a trunk for that
Yep - absolutely.
I did try cross cutting as deep as I could and then trying to split out chunks by hitting the endgrain with a maul.
However swinging an 8lb splitting maul from overhead to impact below and between your feet while standing on the trunk was so obviously a BAD idea that I didnt try it a second time ... not that it worked first time either.
dependant on your experience & respect of bigger saws i would suggest looking on the big auction site, a stihl 051, 076 would be perfect, then re-sell the saw once done....... these are powerful saws, as long as you remember that then it could save a lot of work for a minimal outlay,, good luck mate
Could try an old 034 stihl
light fairly small but pack a blinking good wallop and will drive an 18 inch bar fine.pick them up pretty cheap too.I use mine all the time and love it
Hello bud, I live in sheffield, away this weekend but got nothing to do next week, so if it's still there I could pop over and blast some off. Only got a 346 with an 18" bar on at the mo but it'll give you an idea of what a pro saw will do before you go and spend your money!
What a damned kind offer. The man is a fool if he doesn't take you up on the offer. Not many like you around buddy:thumbup1:
Thats a very kind offer indeed ! Many thanks. It would be a great chance to see it in action...
I'm up in Bents Green S11 - message [being] sent.
When you're done polish it up, varnish it and nail it up over the fireplace?
:001_tongue:
Funnily enough - just suggested exactly that to the Mrs
[not sure she was convinced though]
