Hi guys
I recently bought a jet winch similar to a tirfor and am having problems operating it probably through my own stupidity. Its a good tool the only problem is once i have winched some thing over i cant get it to release the wire rope so i can pull it out. I am stuck pumping the handle for ages feeding the rope out to put it away. The instructions are in very broken english and i cant really decipher them. Any one using one. Any advice would be welcome.
if its anything like the one i use try putting all the leavers pointing forward and push release leaver forward. i normally have to put front end on the ground and then push down. but dont know if its a jet winch or some other make
Hi mate,
Put both silver levers pointing back, and then push the front black lever HARD back aswell, it will go just needs some encouragement.
Hope that helps
Yeah, if it's the 5 ton version both levers pointing back then push the front handle back and downwards by hand it should lock into a position and stay there - that will allow you to pull the cable out freely.
Don't use your feet on the front handle though as I tried this and the handle snapped, had to wait 6 months for the new part.
The handle should just push forward when you've finished. The handle has to be in the backwards position though inorder to feed the cable back innext time you use it.
The Jet Rope Hoist is a great winch so long as you look after it
