ive got a job coming up, its occured to me is there a way of checking if its a council house or not? without sounding rude it looks like it could be. i could see the situation of someone wanting the tree removing, the council not doing it as its not DDD, and the tennant having it done himself!!
any advice much appreciated
haha, to be honest id thought of that, but me not being the most tactful, id probably come across being a bit rude!
You just need in you t and c that the tree the clients wants work on is their own.
If it's not TPOd or subject to planning restrictions then if the property is council owned the tenant can do what they want. A TPO check should confirm.
According to my tenancy handbook, all trees are under the ownership and responsibility of the Council, permission must be sought before cutting or removing them, and a suitably qualified and insured contractor must be used.
cheers guys, unfortunately ive only just thought about it, and its too late to ring the council as i wanted to do it at the weekend, but found a website called mouseprice, while ill not take it for gospel it suggests its not council homes.
