it has been "out of the frying pan into the fire" for the blue machine, not good for all the guys still there that I used to work with. I hope there is a light at the end of the tunnel for you all. not good either for those who are owed money for work done, could have quite an affect on the industry with alot of changes of tee shirts!:vroam:
Connaught have only liquidated the GM contracting arm of the company.... so unless you cut grass then no contracts up for grabs... also TUPE would apply on most LA contracts so you may inherit a real headache....
