Decay images
David Humphries
Urban ash that's been in decline for the last couple of years.
Slight lean toward the road and foot path.
We inspect this tree once a year and hadn't noted any fungi fruiting other than Daldinia around some older prunning wounds.
Put the Resistograph the base of the stem to see what was going on.
Roadside showed sound wood until a central decay about 30cm in.
Opposite side showed less sound wood (about 12cm) before it hits the decay/cavity
The quadrant reading taken between the above two appeared a lot more significant
Edited by David Humphries
We took the tree down last week and had a look at the cross section at the base earlier today.
The above cross sections appear to show a brown rot toward the outside (not confirmed, but I suspect Rigidoporus ulmarius) and a white rot toward the centre. The cavity wall was coated by Melanine, which is likely to be Armillaria.
Always interesting to see how the Resistograph compares to the cross section
ImageUploadedByArbtalk1464805909.761870.jpg.94984ee2b711d1d0777ac1afbc69c8ed.jpg.
[ATTACH]205719[/ATTACH]
[ATTACH]205720[/ATTACH]
[ATTACH]205721[/ATTACH]
[ATTACH]205722[/ATTACH].
The resistagraph is an amazing tool which I would love to own one day. Did you suspect cavities before the drill David?
Can you expand a little more on the Melanine on the cavity wall please. I tried a quick search but couldn't find anything:what:
Sorry Jake, I should have probably expanded on that a bit more.
Melanine is a black coating that Armillaria mycelium lays down protecting the wood against elements and other organisms for its own benefit.
I believe it's made of the same substance as the black coating seen on Rhizomorphs.
See post 5 of this thread below.....
http://arbtalk.co.uk/forum/fungi-pictures/29219-armilaria-central-cavity-decayer.html
Wow, fascinating thread. Thanks for the share. Iv seen so many melanine plates on trees I have removed and never known what it is. That thread leads me to believe armillaria is a lot more common than I first thought.
Interesting pattern of decay and dysfunction in this pond side sycamore.
We had to raise the canopy for access (which will make it more hospitable to bats)
The base of the stem and the cavity have fruiting bodies of Kretzschmaria deusta
The disc was taken from a collar of a side branch near to the top of the cavitation.
ImageUploadedByArbtalk1465323045.471291.jpg.d6ce4023448821a21cde108ff4b287cd.jpg.
