Go on then. What do I get for this?
Nowt wrong with high back cut considering back Leaner!
Stump low as possible 2pts
Nice landrover 4pts
Extra 3 bonus points if hinge was intentionally thicker on jack side :thumbup:
So 9 points but did you really need all those wedges? ;-)
On the subject of high back cuts, if there is no, or little chance of the tree shooting back on the stump, I make my back cut level with the bottom of the face. Less timber wastage & a reduced chance of over cutting - thoughts?
Precisely Pete :thumbup:
Increased chance of fibre pull?
I don't see how - you can cut the hinge finer as you do not have to compensate for the longer fibres if you think it might be a problem.
Agreed, the fibre pull was just a thought as it does seem to increase with a low back cut and a normal thickness in the hinge. Low back cut also gives better control over direction, particularly if there's a bit of a side lean.
Luftwaffe, these trees were in groups, each seemed to block the other from felling across the racks. It was easier to fell them in with the jack and with the angle of the rack there were only a few branches on the timber the harvester had felled. The forwarder knew we were coming and could have cleaned it out the day before but didn't, so.......
yes I know what you mean. do you cut the whole tree into lenghs or just fell and trim? I just fell and trim and cut the first couple of pieces off if they are too big for the head, the harvester comes along after I have finished and cuts the tree to lengh.
its a hard old game especially if there is a long walk in with all the clobber!!
Cut to length if we have to, only if the harvester has already moved site or is too far away to make it back to process a couple of trees. Most of the time fell and run out if needed until the machine can cope with the branches, knock a log or even two off if the trees are too big. How much processing depends on which harvester is on site. Carrying stuff in can be a job in itself, especially up hill, but if you get a kind operator with a big cab it can help. :thumbup1: Often need to buy them some spray cleaner for the cab afterwards! :lol:
