is it ok to hang chainsaw (066)from the bottom hole of hitch climber? its what i was doing the other day whilst removing some pines so to take the weight of my harness while i was waiting for ground to be cleared. worked reallyy well just wanted to make sure it was ok
what about if you did it with a tear away strop. but then dont think you can use then with the weight of a 066?
