opinions please??
MattyF
Looked at this corsican pine on friday ,very healthy tree but is surrounded by flats built on 3 sides around it....obviously there has been a number of limbs taken off around the trunk resulting in callus growth and swelling but the base appears smaller than the trunk so i am thinking there could be problems??any opinions would be much apreciated.
http://IMG_0070.jpg
I agree, but would it not be the case that if the ground level had been raised by enough to cover flare then there would be visible effects higher in the tree?
I cant see any other reason than a rise in ground though....
Looks all a bit recently done,at a guess in the last 2 years,maybe less.
Good point. As said, it might be a bit early yet. Also, any deterioration in the crown could also depend on the soil type. If the raised level is made up of a sandy free-draining soil then the tree may learn to adapt. If the new soil were a heavier clay or had been compacted post construction then the tree would prob deteriorate more quickly.
That's what I reckon anyway.
