42" husky bar
ben lightfoot
Im after a 42" bar and chain for a 3120 but struggling to find a place that just sells them separately (going by websites that is). Also would a 42 fit on a 395?
cheers
ben
Hi Ben
Rob Dyer can help you he is on here and i will pm you his mobile, he is also in Hants.
Regards
Les
I have a 42" woodlandpro (cannon) bar for a Husq.
Chains you would prob be better getting of Justin.
It will also fit on a 395 but bear in mind the standard pitch chain for a 395 is 3/8 and guage is .058 where the standard on the 3120 is .404 guage .063.
So you would either have to a) have a 3/8 nose sprocket on this bar which can be done or b) put a .404 drive sprocket (or rim if rim and sprocket set up) on your 395 when using this bar and chain with it.
