Just been doing a bit of maintanence on a couple of our older ms200t's and noticed a hair line crack in the small metal pin located in the housing bolted to the carb. This pin is what holds the air filter cover on.
I lost an engine to this a while back but didnt realise what had done the damage until now!
If you dont ever remove the air cleaner then yours is probably fine :D but its got to be worth having a look since it might save a few quid in the long run.
The crack is difficult to see but worth checking out.
BTW just had a look and the part that needs replacing is called the filter base and should cost less than a tenner.
part no 1129 120 3402 @£5.87 + vat
I have had no problems with that part but ....
in Jan the D ring on the back of my 200T cracked off and allowed my saw to fall 4m onto a concrete path. Check that bit too.
I was shimmying down a diagonal ash stem, about 12in diameter, cutting 1ft rings off, and i caught my sack on a stub. I panicked because, for about 20 seconds, I couldn't release my weight!
I thought they were gonna have to amputate!
