impact drivers
DN22 Gardening
doing lots of raised sleeper beds atm.
got the full set of ryobi one+ stuff, and am very happy with the quality of the stuff.
only problem is, their impact driver getsw through a battery every half a dozen screws, ok so they're the 9" long things !!!!!:blushing:
can anyone recomend a 240v one.
just ordered a box of 6" 5mm drill bits to get through one sleeper, we'll see how this goes
thanks
dave
dn22 gardening
I use bolts for sleepers as its easer to drill right threw both sleepers then to use 2 ratchets/sockets + it makes a mechanically stronger connection.
If you use one of them flat wood boring bits you can countersink the head of the bolt on the side that’s on view and if you use “self colour” bolts/washers the heads will rust to mach the sleepers colour so look much better after a bit of time than BZP etc and other bolt/screw treatments.
But either way drilling sleepers you need to go for 110v or 240v
But most of my past work with sleepers have been for retaining soil/embankment rather than “beds”
there talking about impact drivers
if you thinking of what mechanics use thats an impact wrench
impact drivers take a 1/4 inch hex screwdriver bit
impact wrenches take a socket
if your happy with your ryobi kit why not get ryobi
also check your batteries for the mah reading if it is <2 as what usually come in the kits
you can buy upto 3 mah ryobi batteries
we use 2.6 mah ryobi drills sometimes and they will loads of 6 inch timberloks depending on what wood it into
Still dont get why you would need to use an impact driver for sleepers.My Dewalt cordless drills will put a Torx head 200mm screw straight through a sleeper and into another, countless times before I need to change the battery. Even the smallest 14.4v will do a good few.:thumbup1:
