its 50/50 whether to get a splice or not, its just they cost so much, unless someone on here would splice it for me if i was going to not get a splice, id buy an extra metre to make up for the lost length tying the bowline, but i dont suppose it matters?
Hi Rob don't want to de-rail your thread but did you get taught to use bowline at college? only i read that it shouldn't be used as a climbing knot 'cos it can't cinch onto your karabiner and may allow biner to rotate and possibly open gate(same prob with figure 8):scared1: or put strain in wrong direction, suggested popular alternative is double fishermans, easy to tie and grips but still unties, others are available:thumbup1:
Can anybody else confirm this?
  • Replies 36
I was taught bowline at college.
i had my own gear before i started at college so used my own, always climbed on a splice, when i use the other end i use a bowline, but to prevent improper loading its just a simple glance every now and again. i could easily use a double fishermans.
i think ill probably end up getting a splice, simply because it is easier and stronger than a knot.
Cool:thumbup:
Eh? A splice cost £20, how is that expensive? You'll get back £20 in time not spent tying and untying knots, plus the satisfaction of having the right tool for the job.
why is a splice the right tool and a knot the wrong tool?
there's nothing wrong with a knot at all.....
a splice will go through (almost) any crotch when retrieving, but the only way to get a bowline etc through most crotches, is to untie and then retie...
i for one would never have the patience for that, plus you can't really use a knot with hitchclimber + vt.
... you can't really use a knot with hitchclimber + vt.
Agree with that. It is generally unsafe to have a knot (of any type) with a hitchclimber/VT setup, since it may catch the VT and prevent it from gripping.
This, in my opinion, is the prime reason for using a spliced/sewn eye.
I climb on a bowline and have for about 3 years. I tie it with a double loop which is purely for my piece of mind.
Sure it occasionally catches on the vt but I just tie it so the bar is on the opposite side.
I started with a 50m rope then got bored of hauling all that unused rope through a crotch so just cut it at about 30m so now I have a 30 and a 20m.
Next rope I will probably go for a splice but mines still got some life in it.:thumbup:
