Power point help!
Hi all, doing a presentation on powerpoint and want to make my bullet pointed staements appear as each click is made so that you get the heading on the first click, then second click gives the first bullet line, and so forth.
Does anyone know how to achieve this in powerpoint both with bulleted text and images?
thanks all:blushing:
OK, Hama. Let's see if this works!
Create a seperate slide for your title.
On the next slide, type ALL of your bullet points.
Choose the first bullet point, that you want to appear, by HIGHLIGHTING it.
Go to 'animation' and 'slide transition'.
Choose an 'entrance'. (The type of transition that you want).
Once completed, you should have the first bullet point where you want it.
Then HIGHLIGHT point two, and repeat.
If this doesn't work it will probably just be a small difference in Power-Point editions. So fiddle about with it - or get back to me.
Dee
Dee
brilliant response, simple and consice!
shall go try!:thumbup:
I'm not an expert in PowerPoint, but you will find those settings in the 'custom animation' department....under the slide show tab. Let me know if you need any further direction, will be pleased to help :001_smile:
Ahh too late....well done WeeDee and much better explained :)
Edited by Yve_Clark
not quick enough!
well thats confuzzled me!!
just write the first one, then start a new slide by copyin, then just add on the next bit.
worked for me!
Ha Ha, thats my technique.
Forget the proper way, just bodge till it seems to work right.:thumbup1:
but that doesnt make it all look cool and flash!
I like the new way! tis quality!
You guys are pucka, cos your always there when i need ya, doing this FdSc I cant ask tutors stuff late at night!
