Mog losing air/air not building up
  • Replies 67
yeah it sure has , i think its called the joys of owning a mog lol , do you get much trouble from your mog huck ??
They work hard and so things wear out and break, they cost a fortune too maintain IME, but make you a slightly bigger fortune, so it works out OK:thumbup:
You need to build up a relationship with AC Price, if you buy all your spares of them, they will give you very good advice over the phone.
:confused1:May already have been mentioned but have you checked the air dryer filter and valve if your mog is fitted with 1, had 1 go on a 1650 that I was using and you could not hear the leak because it was venting as fast as the comp was producing air.
Just a thought from my limited knowledge:thumbup1:
