If it's the ones on the rollers John you'll be as well getting extended grease nipples, they often break because it's in a tight spot and getting the greasegun back off you have to twist to the side levering the nipple and snapping it
thats what happened
  John Shutler said:
thats what happened
You can buy like a little extension tube about 3/4 inch long which brings the nipple out where you can see it.
But hey.......John..... I'm sure you know how to bring nipples out where you can see them, I'm surely teaching you how to suck eggs so to speak :lol:
  • 1 year later...
i need some as well just got myself a tw150dh and snapped the nipple off from the feed roller, what size are they coz theres loads on ebay, also if the feed roller does not feed in but does reverse feed, is it that the rollers just need grease....hmmmmmmmmm
Its time for me to service my TW150 an was just wondering how many grease nipples are there exaxtly, just so i dont miss 1!! Also is there a particular grease you use? Thanks in advance an hope u dont think im hi-jacking your post! Just while ur on the subject an all that...
One on each feed roller, two on the brake system if it's a braked tow behind and mine has got an extra 4, two on each side of the slider that the top roller is on.
Read more
