My current throw line setup , is a two in one.
Using the stein 1.8 mm yellow line and splicing with this stuff 26980d382e332203d6508b68a4357dd5.jpg
2 mm polypropylene line which is quite stiff.
For me it's the best of both worlds , one side strong and static for pulling ropes up and the throwing end weak enough too break if need be.
Here's some pictures for throw line splicing.
0c79cf2f5c8a9f0d40f25e2a279ab0ec.jpg4b7022038f24e417d35ee0bc1f243098.jpg62d1a566e763c649ddc647a29601e9e2.jpg8d7cdb0c70333ca01b034a8a0d18176e.jpga0260990084115d1bb3540e5c7997ea7.jpg
Splicing a 2 mm line into a 1.8 mm line helps if you use a fid of some kind7d6e096a2ec31dc291d258f773d8ba4f.jpg
Sent from my iPad using Arbtalk
  • Replies 57
I didn't like using the yellow stein throw line , for the first few weeks it was brilliant until the coating wore off .
So i thought the two in one would be good solution and I'm quite satisfied.
Having said that , i've been told everyone buys the pink stein throw line.
But still , i like being able to break the stuff if need be.
Only ever used Zing it once its bedded in its alright.
If it gets stuck, well that's why I have 3 throwline sets, if all three get stuck its time to go home.
