wet work
Tom D
  • Replies 21
I was wondering that, I have seen a few tractors on with tyres the 'wrong' way round, always assumed that there is a reason for it.
R
Extra grip when going backwards im guessing :confused1: Dont know for sure tho
b101uk explained it one night, very clever, so i will do it and not pretend i knew why.
Tyres facing forward get 100% possible traction, but when you reverse each tyre only gets 70%, so thats 400% forward 280% backwards. so if you turn the back ones the other way around, you get 340% in both directions. So therefore better traction in both directions. How cool is that.:thumbup1:
Although its better to turn the set that will be under the most weight, which on my tractor would be the front set (when reversing up a hill) or using the loader. In the days before telehandlers you used to see a lot of tractors with front loaders and with the back tyres on backwards for reversing out of muck heaps.
TBH I like the 400% forwards at the mo as I want maximum grip when digging the bucket into the logpile, however when towing off road the tractor is noticably worse going backwards so if I get a timber trailer I will turn the front tyres.:001_smile:
ballasted tyres are great until you get a puncture and have to take the tyre off, better way to go is hub mounted weights.
it`s ok to just fill with air but you never get round to ballasting them up agian and you use lots of aanti frezze.
