4 hours ago, kram said:
Yeah very easy to splice 3 strand.
That brings an unrelated question. If one looks in shops at rigging ropes, all of the spliced onces have very large eyes - much bigger than a biner. Whats the intended purpose or reasoning?
@AHPP ?
The reason I ask, I might splice one end of this,
One end for biner and slings, other end for knotting. Any reason not to be a normal small eye like a climbing rope?
Interesting question, Ill ask a couple of rope manufactures. I always presumed that it was more difficult to make a small eye splice therefore more expensive.
I don't know if there are any regs on the size of a spliced eye on PPE climbing lines as they all seem to be very tight.
Climb line splices are generally tighter to keep the splice somewhat captive on a carabiner. There is no benefit for a large eye.
Most decent manufacturers use a "thin splice" to aid in installation of non mid line attachable devices (ZIG-ZAG) and for the effective retrieval through modern cambium adverts where the traditional double braid splice would interfere.
As far as the regs go, they need to meet the relevant EN criteria
I understand the captive bit but some of them really tight! We've had the odd customer complain about it.
@AHPP ?
If the spliced eye on a rigging line is large.
I was told the larger the eye the more material is available in the even of shock loading.  Similar to a rigging system, the more rope the system the more stretch is available when it gets shock loaded.
Large splices in dead eye slings are for similar reason.  The added advantage is when uou cow hitch or tie off, the throat of the splice is not directly in the knot.
The process is exactly the same for any eye size, large just uses slightly more rope.
I dont believe a couple of inches in the eye will make any difference for a rigging line.
Edited by kram
True but maybe you need to be more precise when splicing a smaller eye so it may take more time, I don't know. There are plenty of splicers in this forum. Maybe they can explain if its more difficult to splice to a specific size.
If they do mess it up then that's a lot of wasted time and rope.
