Hi all
I’m just seen if anyone  is running a ST8p with the Kubota petrol engine and what there views
We are running at st6p 40hp at the moment and thinking of adding another petrol to the line up
but would consider if running a st8d too
Thanks
Peter
I didn't know that there was a petrol option for the ST8. Im not normally a fan of petrol engine chippers but having used the 57hp Kubota powered Timberwolf 280 my mind has been changed.  Performance could easily be confused for a diesel although I do wonder about longevity of a petrol chipper compared to a diesel.
If your impressed with the ST6p then if the St8p has the same Kubota petrol you will be blown away.
I'm not sure the ST8 would be my choice in 8 inch machines but I do know why people like them.
The St8p has been for sale Norway for a while now.
The link below is to the Norwegian dealer but Bensin means petrol.
  • Kraftig motor: 57 hk Kubota bensinmotor for stabil og effektiv drift.
WWW.STUBBESERVICE.NO
Denne flishuggeren er laget for å takle krevende oppgaver med en kombinasjon av styrke, fleksibilitet og...
On 30/12/2025 at 23:57, NJA said:
Don't think it'll be a kubota engine if its petrol either?
Its probably brings and Stratton,  rebadged. It won't be kholer engine as they , I believe are still tide in with lombardini... hence kholer diesels
Ive hired a st8 twice and both times it went wrong and the hire company had to come out to fix it! id go for schliesing 220mx personally
Any hire chipper is likely going to be abused. As with all machines good operators and mechanical sympathy go a long way.
One of the worst chippers I've ever seej was a ST6p. It had done 50 hours, blades were nacketed, rollers chipped no oil in the engine and the prop shaft to the pump was baked in hazard tape and fencing wire. Same as the flywheel bearings.
I think one of the best chippers I've used was the vari track ST8. The Greenmech really makes the most of the smaller engine. The Schlising,and  Bandits even the vermeers are in a different league.
People still speculating what the engine is if they even do a P go the St8.
Did no one look at the link I posted.  Been out ages here and the details are there for all to see.
57HK Kubota Petrol Engine.
