I moved in a month ago and was suspicious of the tree health of my ash
I've had someone to look at it and it appears the tree base is rotten
I can put my arm up inside the trunk.
I am devastated at the thought of having to cut it down.
One person said they could pollard the top to take the stress out of the trunk and it might give me a couple if years.
The other guy said she to the fact he can get his arm up the centre and it's all soft and rotten it is best to fell it.
I am devastated.
Note I didn't add the hoop or the electrics around the base.
Looks pretty goosed. Topping it might well make it safe enough to stand up for a couple more years, however you’ll just be left with an ugly tree and 2 bills to pay. One for the pollard and a second one for its inevitable removal down the line .
On the flip side if you fell it now, those couple more years you might have been able to enjoy it for can be used to establish a replacement for you to enjoy for many years to come. Fell it now while the firewood is still half decent
  • Like 8
If you really want to make as sure as you can be that the decay is as bad as it looks find a consultant with some decay detection equipment such as a Resistograph or even better sonic tomography such as a Picus. The consultant can then write a tree report and recommend a course of action which may involve felling, or pollarding or retention of a spar for habitat, neither of which look "ugly" imho.
From the photos you've posted it doesn't look great, but if you're willing to spend ~£500 for a detailed report you will have the best information available. The last thing you want is to condemn it only to find with the last few cuts that it was viable for a good few years more.
The tree is only a problem if it is a risk. Or offensive to the eye. Otherwise it is and will incresingly be good habitat for bug and birds.
A good topping mught leave it safe for a  few years, but will accelerate its decline, even if it appears to reinvigrate it temporarily. It might then be possible to leave it to disintegrate slowly and safely. Might be an idea to plant a replacement (I suggest Claret Ash) behind it to get it established for the future.
Thanks for all your opinions. it seems most of the tap root has gone. I can hug the root tendrils at the front. I cn get  branch up the inside for quite a way.
I am tempted to get it cut to a point that it's safe and not going to kill anyone when it does fall.
