The chain is far too aggressive for such a small bit of kit that’s intended for pruning ect iv been trying to find a chain and sprocket that works with it but The chain and sprocket on the m18 hatchet is unique to the brand   So I can’t find any ways around it so I can run a smaller gauge chain, wondering if anyone else has had the problem and solved it?
After a year's use with mine, I'd say you'll find that you get used to it, within a week or two.
But do avoid/be extremely careful when cutting with the top-side of the bar... it does have really lethal kick back.
Always use cut resistant gloves AND sleeves.
No 'one handing ' ever !
The set-up on the equivalent 40v Makita pruning saw however, is much nicer to use. Tho the 18v Makita version is a bit underwhelming for professional use IMO.
The Sthil AGT40 was OK, too.
Assuming its all new, first option is a light sharpen but leave the rakers, it will reduce the chip thickness, therefore be less agressive. I've seen a few chains that come a bit agressive/rakers too low out of the box.
One issue with these small pruning saws is they have a slow chain speed, that lets it dig in more on small branches. I think its for some safety reason rather than any technical limitation of it being a small saw, yet it has the opposite effect!
Standard chain looks to be 3/8" 1.1 gauge. Stihl do a full chisel version which should cut a lot smoother, due to being sharper.
While 1/4" has smaller teeth, more teeth in contact with wood eats more power. Can be smoother.
Theres the .325, Oregons Speedcut nano, which Makita use on the UC029, my opinion its not much different to the narrow 3/8lp chains.
Edited by kram
I had the same problem with my one handed Makita DUC150 chainsaw.  As above, I have sharpened the teeth until the gap to the rakers about 50% of how it started, about 10 thousandths now.
Not entirely the same, but I put a 12" Rotatech chain on my Kombi pole saw. It was noticeably not cutting smoothly, but bouncing about a lot. I have a second attachment with a 16" bar from an 023 fitted to it, with a Stihl chain. That's much smoother, so I may check raker height. Interesting.
I got given a Hawksmoor mains electric chainsaw (to save annoying the neighbours) that was just the same, semi chisel, low profile.
Apart from that for 60 quid I'm impressed.
You want this - one of these bars and chains here:
One of these sprockets:
WWW.CHAINSAWBARS.CO.UK
Carving Sprocket 1/4 x9 tooth [Makita XCU03, XCU04, XCU06, DUC303, DUC353, DUC254s, DUC256s, DUC305s, DUC306s...
You can also try a full chisel chain here:
It transforms the saw... I wonder if Milwalkee will catch on ;)
20% off arbtalk discount only use the Coupon MILK at checkout.
This cannot be applied retrospectively ie. 'Hey I bought a bar and chain last week but saw you were doing a deal on arbtalk - can I get that discount applied?'
