Idea: Willow. Hack a load of nicks into it and then bury it in a trench, either completely or with the top showing. Hope it comes up like a bamboo screen.
Horizontal or one end a bit up like a hedge pleacher?
Have no fear. Any sticks of willow 1"-4" lain flat in a wet ditch will sprout profusely. But get them in now and keep them wet: the sprouting season is upon us.
I've been working on the restoration of a silted up area above an old pond; as I cut the willow back (back in jan, feb) I was cutting it in to lengths and make a number of track-ways across the soft, wet, marshy ground: they are all now sprouting.
ETA PS just re-read your post: no need to hack the nicks.
Edited by Yournamehere
cos I didn't think of it earlier
To be Hügelhedging you'd need to plant it on a mound with buried stumps, logs, bodies etc.
I've planted some goat willow cuttings/rods/logs horizontally this year as I've left a few rods laying about in the past when plating rods normally and they've grown.
I didn't bother nicking the bark at all as they tend to root and shoot from any buds. I planted mine in a small trench, partly to keep them moist and partly so the horizontal scion doesnt become a trip hazard in future. Mine are just showing their first shoots after planting a couple of months ago. I water occasionally in this dry spring weather.
Edited by Paul in the woods
3 hours ago, AHPP said:
Cap with soil, woodchip or nothing?
No, nothing, leave em open to the light & air - just as long as the lower half is in the wet you'll be fine.
Like I said mine were used as an walk-way across marshy ground and so just lightly pressed in with the top surface still showing.
I'll be down there again over the w/e: I'll take some pics.
I planted more willow cuttings this winter by a roadside (in the dark) driving/cycling past you can see the new shoots, they're coming on well.
Yergo. A few pics as promised. These two to start were when we started back in January very dank and dreary; very soft ground so everything cut to saw length and used to make trackways.
(I've reduced the pics to ~300kb: see how they look, if still too much, I'll do a quick edit)
IMG_3027.JPG.83cb31d16d4a310dfb0615d42378e352.JPGIMG_3033.JPG.3ce5decaa0929a56bca7a1e414638a97.JPG
