Hi I am a novice saw owner I was looking to replace a stolen ms 170  and saw 2 ms 440s in a auction a barn find supposedly both were seized when I got them home Im a pensioner with time on my hands so had ago at fixing them the piston looks like something has gone in from the carb side and a bit was fouling the crank the pot looked OK so ordered a piston and gasket they were 50 ml checked the duff one it was 46 ml the only badge on it is on the clutch cover ms 440 made in germany  only 46 ml pistons I found were for ms290 and ms340 all good experience but will it ever live again
What ever you do , if you fix it make sure you determine the reason for the seizure ( air leak , bad fuel mix etc etc ) because if you don't sort that it will quickly happen again .
