16 hours ago, doobin said:
It’s simple. It’s because you’re using flux core.
flux core is nothing more than an auto feed arc welder. You will have all the same problems repeatedly striking and arc, of putting enough power into it to penetrate rusty metal without blowing through. So you set it lower to not blow through and you’re surprised when your welds are crap.
Get yourself down your local motor factors and get a bottle of sgs or hobbyweld rent free 5% mig gas.
basically until you strike the arc and start burning, the flux isn’t burning off the give your weld protection.  There’s always a delay when staining the arc and the protection is nothing like the surround of gas from a mig shroud either. Because you have to keep stopping and starting your welds are crap. Using a proper mig, the gas is always protecting your welds, so you can start, stop just before blow through, wait a split second for the red hot glow to dissapate and then go again, all whilst protecting the weld with gas.
Interesting that does make sense. I can get decent flux core results when welding thick metal, more power and longer periods of welding.  Its any thin metal or repeatedly tack welding where the results are poor.
I do have some proper MIG wire and a few disposable gas cans.
Thanks.
Thanks.
Be careful as the disposable cans are usually just co2 which is not the best shielding gas. It’ll give you a similar messy result a lot of the time.
if you want a decent job especially on shitty thin metal then you need a 5% argon mix.
Actually Ive just checked and my disposable cans are 86% argon, 14% CO2. What about that?
I'll do some testing first. Last time I tried them my local Hobbyweld only had massive canisters and were trying to puish me towards rental which annoyed me. I'll try them again.
Edited by Muddy42
9 minutes ago, Muddy42 said:
Yes CO2. OK, I'll do some testing first. Last time I tried them my local Hobbyweld only had massive canisters. I'll try them again.
They might be big cylinders, but it's not rental.
Think the tank I've got in the shed is about 5 years old and still 3/4 full, costly but not bad for the occasional user Vs those little machinemart rip offs.
14% argon is what’s called a ‘heavy’ welding gas mix. It’s for
welding thicker steels, it lets you get the heat into it more easily with greater penetration. If you’re used to 5% gas it’s remarkable the difference it makes- your dial positions pretty much end up swapping over, with more wire feed than voltage for once.
I keep a bottle at the yard mainly for site work, welding RSJs and the like. It’s not really what you want for a thin mower deck, and it also gives a much messier weld with more splatter than 5%.
go on, treat yourself to a bottle of the good stuff. It’s just a deposit and then the price per fill. Get your deposit back when you decide you don’t need the bottle anymore.
Edited by doobin
Thanks for all your help.  As its the only gas I have, I used this and swapped back to normal wire on the mower deck.  Yes there was splatter, but I can tell the weld is penetrating better and is stronger.  For the remaining holes, I stopped trying to do fancy but joints and made patches to overlap the holes and welded them from both sides.  Its a mower so strength and function is more important than looks.
Back to the gas, I guess that explains why I was getting amazing results with this heavy gas on thicker metal then.  But for thick stuff I was also getting pretty decent results with flux core.  So once this is used up I'll get some 5% stuff.
Thanks again.
Thanks again.
I didn't realise you were trying to do butt joints, that'll test even a skilled mig welder on a rusty mower deck. You'd want gas for sure and also .6mm wire would give you a lot more control. The problem with butt joints is also that you would have been bringing all the contamination from underneath the deck into the weld pool, and usually there is only a mm or so of decent metal to use.
Overlaps joints on a mower deck are easy with a MIG- have it set a touch on the warm/high voltage side, start your arc on the new plate and melt it down into the weaker, more contaminated metal underneath. If thickness allows you can weave back onto the high plate, but it's often easier and faster just to let off and then repeat the process for a series of blobs. If done right this is as strong as you'll get given the weaker underlying metal.
