It's called a key, pair of wire cutters and it should come out.
Plus that bearing is probably the locking collar type with a grub screw, unless it's just a spacer.
Edited by GarethM
  On 16/11/2024 at 17:56, Mike Hill said:
TL
Taper lock?
Expand
Even if it's just a spacer instead of a taper lock, he'll need a big wrench to free it anticlockwise as it'll be tightened and full of sawdust.
And note, remove the spark plug leads!.
Are the bearings shot, noisy as that looked pretty ok.
Edited by GarethM
Expand
There is a lot of play with the bearing and when is slowing noise of metal banging cames from it.
Please @Gareth M the spark plug leads because of?
Edited by naturarbo
Read more
