53 minutes ago, richyrich said:
Is this same make to the one Crytec import? It looks similar but with 2x flywheel/pulleys and wider axle??
Yes there all Chinese, this is the newer type, I made the wider axle as a temp measure for it as there top heavy.
I'll be removing the axle and mounting it onto a small trailer with turntable to make more useable.
On 23/02/2025 at 09:03, slack ma girdle said:
The different lengths that the log chomper produces can be a pain
I still cannot see why it should produce different length cuts. I had thought it would always cut the distance two blades are apart.
Can anyone explain why?
1 hour ago, Splitter said:
Do you have a link to where you got this from? As I've seen with others I'm thinking this could be a good option for processing hazel etc for putting in the charcoal kiln.
Its the diameter of the log. The bigger the log the shorter the distance the blades have to travel before they bite into the next log. So a 2" diameter log will come out around 9" long, and a 7" diameter log will come out around 5" long.
Yours shears through 7"? I would be quite happy with one that cut up to 4" if the length were no more than 9" for small stuff and at least 6" for 4" stuff.
Edited by openspaceman
logic
I think he's just using them sizes as an example, when I looked at this model the max size was 110mm, maybe in practice it does get more though.
So in practice what are the length variations on your? How heavy is it? Is it available to buy my side of the water?
The one I have is available in UK
It cuts up to 5".thick
As a guide a cut 3" to 4" fresh and 5"dry.
In length I get between 6" to 10"
If you hit a big knot or joint in the branch you can stall it, but with practice you can get on well with it.
Here's some fresh cut beech a week or so ago showing diameters.
It's a game changer for me on our smallholding, as much of what I'm needing to cut is sub 6" thick.
I can also process the leftover thin branches and twigs into a small pile for burning, or shoot them into the hedges row.
Edited by Splitter
I've got the RP200 with extra flywheel, powered by a 180hp Valtra, so it cuts most woods at 7".
I try and keep it to 6" and below.
It is a shame you are so far away as I would buy a few logs from it, sizes seem just right for me, I would need to rethink storage and seasoning.
