Seeking advice on best tool to deal with bramble infestation
  On 16/12/2024 at 20:06, Eglijim said:
Have a similar problem with a heavy bramble issue spreading from our boundary hedges and treeline and been looking for an affordable semi pro brush cutter for a while . I know of no battery tool up to the job at any price so guess you will have to go gas powered .
Expand
I often use the Husky battery brush cutter with a mulching blade on stuff a lot heavier than bramble, you can even use it as a clearing saw and fell small trees
Edited by scbk
  On 17/12/2024 at 17:00, scbk said:
I often use the Husky battery brush cutter with a mulching blade of stuff a lot heavier than bramble, you can even use it as a clearing saw and fell small trees
Expand
Is that the 535 brushcutters. I've used mine with the clearing saw on which is good. I've only used grass blades and the tribade on bramble. Does it run the mulcher blade well.
Yes it's fine with a mulching blade, needs to be the 3mm thick blade.
Personally I prefer 4 stroke or battery for running a blade than 2 stroke
Read more
