Hi,
Looking for some advice on fliplines..
Today I nicked my flipline ( not a steel core) is there any way the rest of the line can be reused as it's cut close to the beginning?
I have never before had to make up a flipline or anything so have no idea what to do..
Just seems a waste throwing away the whole line..
Look forward to hearing the advice
As Mark says, cut it and tie it back on, barrel knot would be my choice, but unlike Mark I'd keep using it for another three or four trims.
CE mark is at the far end, is it? Would LOLER be a problem with a quick fix? Might be less hassle to just buy a new one, but that's a lot of hardware going to waste.
50 minutes ago, Mark Bolam said:
I wouldn’t waste it Peds, I’d reuse it on a new piece of rope.
Understood, I meant the rope as well though, my current flip line is shorter than that... but there aren't any trees big enough to need anything longer.
In fact, Maxd, would you send me that snippet you're about to cut off? It'd actually be an upgrade for me...
This is the current state of affairs..
I have taken the swivel carabiner off and reattached it to the longer length using a bowline knot..
Edited by Maxd
Now, I'm sure others will disagree with me, but I wouldn't be using a bowline for that attachment. Fisherman's or barrel, cinched up tight.
Bowlines are of course a safe attachment, but they have a habit of working loose when weighted, unweighted, left alone, dangled for a bit, weighted, unweighted, ignored, etc... as might happen with a lanyard.
Edited by peds
Not sure even Johnsond would disagree with you on that.  That use of a bowline is just plain horrible.
  • Haha 3
