43 minutes ago, Donnie said:
I’ve honestly worked all over and I can barely remember where and what we were doing on each job to be honest…
That's inexcusable at your age 🙂
Whitelaw Brae is halfway between Badlieu and the Fruid reservoir
Haha. I’ve done a lot in Fruid reservoir. Made a door in the tunnell that goes all the way underneath it. Cool bit.
Tell me more. That sounds very interesting.
Here’s the outlet/overflow pipe 4 floors down an elevator at Fruid running fairly constant. That goes and feeds the river etc.
Some photos from the Megget tower at the top, that’s impressive in there.
Here’s some photos I’ve found off of my phone from some other resevoirs I worked on before I quit/got the sack and went into the woods.
Would of still been doing it if I were with a good company. Quite interesting the different processes there is to making water drinkable, loads of different processes… Albeit very very slow.
All the pipes/inside photos are of Meggett going up the tower.
It’s not all that interesting. Was just a 10-15 minute walk under the res in a 1 metre or so wide tunnell to the other end.
We made an arc’d door frame to suit out of nylon sheet and attached a 3 phase fan at the top to circulate the air and demist the tunnel.
Some of the photos of the resevoirs we had dive teams come in and fit/mount/weigh down these stainless steel frames that we fabricated to hold perforated sheet rolled into a tube that was capped and airline fittings welded into it.
Cored a 300mm hole out through the small resevoir tower, fed ducting down the side of the tower and mounted it off of a rope and harness.
Then the divers came and done the underwater bit (who would have thought…)
Attaching the airlines to the frames.
2 single phase compressors in the tower, running constantly 24/7, one on standby the other working.
All to aerate the water around the inlet of the tower and keep algae away from the inlet/reducing the level of sludge and other dirt coming into the nearby water station.
6 minutes ago, GarethM said:
And when you think most of that pre modernization was designed by some bloke in the 1800s with nothing more than pencil and a spirit level!.
Meggett was built in the 60/-80s I think.
They flooded my cutting partners aunties house when they opened it up. I’m sure there’s a school in there as well…
The first engineering company/who I did my apprenticeship also did a lot of the steelwork in there.
If I find more videos or photos I’ll post them.
Safe to say I’ve derailed my own thread
Splendid work chaps
Edited by Donnie
