Stihl 026 PRO
panorain
7 hours ago, peatff said:
Run it with a drill on the flywheel nut ?
I think that was the plan until Openspaceman found that the coil had stopped sparking all together (going by the posts above …)
I have a starter pulley that has a hex drill adapter for stihl.
It's not a good idea to drive off the flywheel nut because when you stop the drill the inertia of the flywheel undoes the nut. I found that out long ago when flywheels had woodruff keys you could replace.
That's a problem I never had.
