36 minutes ago, openspaceman said:
I suppose it's mostly council depots that have the facility to compress the gas into the tank? I wonder how many litres of compressed natural gas you would need for a litre of petrol (about 8kWh)
It's supplied already compressed from the refinery, makes your gas main or tank outside your home look a bit pedestrian tho.
Fun to fuel up on a winters day as it's like -40 on the metal handle.
Thing is alot of the bad rumours surrounding LPG us from conversion on already rubbish engines like rover v8s .
Put a kit on a proper fuel injected v8 and you can't tell the difference between gas or petrol unless you are towing.
I have put 200,000km on a chevy 5.7 running in gas. Had the heads off at about 180k to replace a soft cam,all the valves and seats were well within spec.
Good engine+good lpg system= no hassel
