Hi I’ve got a MS362 2013 model in very good condition but needs a new piston and barrel, can anyone advise on whether it’s worth replacing the saw or fixing the saw due to new model?
That’s my worry, this saw still works I think it’s just the piston is scored so lacks power when cutting big logs. I just wanted to know if the new saws being m-tronic are as good?
The Mtronic version seems to run stronger than the carb model. Your repair very much depends on if the cylinder can be reworked and the route cause found and if you can find someone to do it economically or not.
How much more is an MS400? That's what I'd buy.
You might save the 362 with just a piston, then it becomes more viable but like Mick says your risk is whatever caused the piston to score in the first place.
