If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
igazz
Hi, getting different advice from Fencing companies about fence post position so thought I would seek advice from persons more knowledgeable about trees than fencing. The fence is getting replaced as well as the posts as they have moved out of alignment. One post however is very close to the Laurel (see photo). The new post ideally would stay in roughly the same position to avoid having half fence panels but it move move about 10 inches 'away' from it.
Is this likely to cause damage to the tree? Another suggestion was to fit the new posts 3ft either of the tree which sounds less damaging to the tree but would probably result in two half panels in the run of fencing which I was trying to avoid.
Is either option unlikey to cause damage to the tree as we don't want to lose it. Thanks
16 answers to this question
Register a new accountSign in
