Our old WP30 processor used to use about 20 - 25L of petrol in an 8 hour shift.
Oddly our current processor also uses 20-25L of Diesel in 8 hours but produces lots more.
Expand
Is that because quieter ?, always found using petrol became something of a gulag style form of punishment.
  • 1 month later...
Expand
Def not quieter. Prob more to do with efficiency curves. The petrol would be at max revs whilst the diesel at just 1.2-1.4k.
Expand
Aren't they both little 3,000rpm engines with the same hi/low pump as the petrol?.
Unless they had the common sense to just fit a constant output pump.
Expand
No, the wp 30 had a little single cylinder honda screaming its t!ts off. The current has a 4 cylinder 2.8l turbo diesel thats running at about 50bhp / 1200rpm but can do 110bhp at 2.5-3k. The wp30 had a single pump. The current a triple stacked pump plus a 10bhp pto pump via a T box.
Expand
Haha, the makes more sense 🙂.
I thought it was bog standard from WP and couldn't get the numbers to work in my mind as I've a single cylinder silent pack, 2000rpm gets around 30lpm.
Expand
The wp was standard with honda petrol.
The Dunn 420 not so much standard ;)
  • 1 month later...
Read more
