  • Replies 34
Only looking at buying with an 18 as I already have a 15 that will fit.
Not interested in the 361 as too heavy, too expensive and I have a 460 for the bigger bars and logging up.
I was looking initially at the 260 as it appears to be the mainstay of general tree work (or am I wrong here). I want a saw I can use all day to replace my 230 (underpowered), hence looking at the 260 but the discussion with the dealer got me thinking hence asking here.
I assume from the replies so far no one has used a 280i are they just too new?
Kev
Kevin - the 260 is a good saw - in your position I'd go for the 260 with a 15" bar.
if you want to run an 18" bar and buy a stihl then go for the 341, the 260 is realy only good for a 13-15" you probably wont notice any difference between the 260 and the 280, i run a 260 with a 13" bar good power and nicely balanced.
in that class a husky 346xp is king ...and cheaper...evan the devout ms 361 fans on AS love this saw it just simply blows every thing away
I run a ms260 with a 13" bar. Cuts very well.
Also use a 16" bar on it with no probs.
Above that Id jump to a 440/460 for a 18/20"
There was an article a few months back in the now defunct F&BT putting the 280i through its paces.
i have owned a 260 with an 18 inch bar and i have to say its not really upto the job. if your wanting a ground saw for snedding limbs and felling small stuff then get a 260 with 15". if you want an 18" bar then get a 341, same power as a 36 but alot cheaper. i just got one off jonesie and its spot on imo. also stihl parts are easier to get hold of and are possible more reliable?
i would go with the ms260, i've got the old 026 with a 15" bar on it & i think its a cracking little saw, i've had it since 1996. I will definetly be buying the ms260 when it finally packs up.
