12 minutes ago, JDon said:
What the hell is a chain brake
Are you not a fan? I love 'em. Makes staggering around piles of brash etc way safer.
Tbf I used to use it a lot but nowadays I never use it. Especially walking up the hill in the morning, at least if you fall on your chain with the brake off (not running) it doesn't seem to cut you as bad 😂
Bad habit to fall into mate.
All that said unless I'm felling a banking/crop trees I'll only be walking 2 metres to the next tree. If doing bigger trees, my saw is turned off on the walk up the hill to the next one.
  • 3 weeks later...
So I've tried both parts.
They both fit the inside mounts.
I only use the inside. But I believe only the 064 bumper spike fits on the outside so if you want to run double spikes you'll need the 064 set
Edited by Ledburyjosh
