Although the video looks dramatic I’d say that’s not an alarming amount of side movement for a slow speed taper bearing application and I shouldn’t think any damage has been done. It only ever sits in one position when loaded. I think you could use a couple of thick washers or a custom made spacer to allow the nut to close it up a bit more, but whatever you do don’t ‘nip it tight’ else bearing destruction will follow very quickly.
If the rear bearings are not seating against the back of the stub axle then yes I would put the spacer here.
Edited by doobin
The whole assembly will seat to the back of the stub axle but then the front bearing is not sitting in its race..... this bearing has gone as far up the stub axle it can so it all needs to be shimmed from the rear to bring it forwards into the front bearing. Also it then needs to protrude a bit from the bottom of the thread so the big washer under the nut can push against the front bearing into the race to seat nicely and eliminate any play.
Edited by swinny
Whever you do, leave a small amount of play. Tapered bearings should never be even 'nipped' tight.
