I need to replace the fuel pipe on a Stihl HS61 - an older machine - and I can't see the part online. Does anyone know what other machines fuel pipes would fit? As far as I can tell it is a fuel pipe with a grommet part way down, not measured it up yet to see what I need though.
(this is the Stihl where they went against conventional wisdom and have the blade up-down instead of across way, as a spares or repair that works but had a leaky fuel tank... replaced and now needs the fuel pipe replaced I reckon)
Thanks
1 hour ago, ChrisNewport said:
WWW.DIYSPAREPARTS.COM
View Stihl HS 60 Petrol Hedgetrimmer (HS60) Parts Diagram , H-HS 60 Gearbox to easily locate and buy the spares that fit this machine.
ITEM 30
It is strange that L&S don't list the part for the hedge cutter but do for some saws
https://www.lsengineers.co.uk/hose-stihl-part-no-1121-358-7705.html
I knew L and S didnt have it on the HS61 diagrams when i wanted one a few years ago, so got mine from DIY spares as above. Now seeing its the same as the MS260 pipe i probably had one in my spares all along. FFS.
Thanks,
I'l look for the MS260 one then - first port of call was L&S spares, a lot of other parts except the one I want of course. \i'd forgotten abouy DIY spares - but I've got things from them before too.
